Product(s): | InRoads |
Version(s): | 08.11.07+ |
Area: | Geometry |
Question:
Where can I get a closure report on a horizontal alignment?
Answer:
Following is the procedure to generate an XML report that will give the closure data of a horizontal alignment:
1. Go to Tools > XML Reports > Geometry
2. Type in the name of your horizontal alignment:
3. Click Apply to bring up the Bentley Civil Report Browser
4. On the left pane, select the report "Traverse.xsl". This report is located in the Geometry folder.
