| Version(s): | 08.11.09+ |
| Area: | Model Interoperability |
Question:
Can I use the CIVIL_iMODEL_INCLUDE_ICM workspace variable to default the settings in the Create ICM command?
Answer:
This configuration variable is used ONLY by the Publish i-model tool in the MicroStation (or Power product) File>Publish i-model… command. This i-model, with ICM data embedded, will be used by the OpenRoads Navigator app.
When the Publish i-model tool is run, it checks this variable to determine whether additional civil metadata (such as linear referencing along alignments) should also be copied into the i-model from the Civil Model. If the variable does not exist, then the icm data (i.e. civil metadata) is not embedded into the i-model. If the value is non-zero as noted below (1,2,or 3) then a temporary icm file is created and embedded within the i-model file.
If the user needs an icm file for export to Trimble Business Center, they will need to run the Model Interoperability>Create ICM tool separately from the Publish i-model tool.
From the Civil Tools help document:
CIVIL_iMODEL_INCLUDE_ICM Set to 1 for Design Models only Set to 2 for Terrain Models only Set to 3 for both Design and Terrain Models | When publishing an i.dgn that will be used as an .imodel for the OpenRoads mobile application, you need to set this CFG variable to 1, 2, or 3 in order to get the embedded civil data (such as linear referencing). |
