| Version(s): | 08.11.09+ |
| Area: | Civil Cells |
Question:
What the best practice for creating superelevation through the civil cell?
Answer:
Superelevation is only applied to corridors. If a corridor is included in a civil cell, superelevation can be applied after placement. Otherwise, you will need to use a geometry rule application.
