| Product(s): | GEOPAK | ||
| Version(s): | V8, 2004 Edition, V8 XM, V8i | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
| Original Author: | Steve Willoughby, Bridge Product Specialist | ||
In order to share geometric data from one application to the next, GEOPAK has the ability to import or export chains and profiles from the Coordinate Geometry dialog to a LandXML file.
Before beginning this process, ensure that you have acess to a GEOPAK GPK file that contains an alignment and/or profile to export.
Structural Product TechNotes And FAQs
