| Product(s): | InRoads |
| Version(s): | 08.11.07+, 08.11.09+ |
| Area: | Basic Settings |
Question:
Is InRoads V8i compatible with AutoCAD on a Windows 7 64bit?
Answer:
V8i SELECTseries2:
CAD Platforms supported with InRoads are MicroStation V8i (SELECTseries 2), MicroStation V8i (SELECTseries 3), AutoCAD 2008, AutoCAD 2009, AutoCAD 2010, AutoCAD 2011, or AutoCAD 2012. The InRoads Group and MX do not support AutoCAD as the platform on a 64 bit operating system. GEOPAK does not support AutoCAD.
V8i SELECTseries3:
CAD Platforms supported with InRoads are MicroStation V8i (SELECTseries 3). InRoads/GEOPAK/MX SS3 does not support AutoCAD.
V8i SELECTseries4:
CAD Platforms supported with InRoads are MicroStation V8i (SELECTseries 3). InRoads/GEOPAK/MX SS4 does not support AutoCAD.
You can also find this information listed in the InRoads readme: C:\Program Files (x86)\Bentley\InRoads Group\readme_InRoads.chm. Please note that there is no version of InRoads that is supported on an AutoCAD platform using a 64 bit operating system.
