Product(s): | InRoads |
Version(s): | 08.11.09+ |
Area: | Corridor Modeling - Superelevation |
This video will demonstrate a required toggle on the Point Properties in the corridor template so the Assign Superelevation can recognize points. If the Superelevation Flag is toggled on for a point in the template, it can be used to assign superelevation in the Corridor. If no points are tagged, the list will be blank and display a warning symbol indicating there are no points available.
Click the video below to play it. To view in fullscreen mode, first click the YouTube link at the bottom of the video to launch the video on the YouTube site. Then, click the fullscreen button (rightmost button at bottom of video).
