| Version(s): | 08.11.09+ |
| Area: | Superelevation |
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group |
Question:
The template point that I would like to select as the Superelevation Point in the Associate Superelevation dialog is not available in the pulldown list.
Answer:
In order for a point to be included in the Superelevation Point list it must be flagged for superelevation in Point Properties. Point Properties is accessible from the Create Template command.
Please also refer to this Wiki article for a video clip demonstration to the issue and resolution:
