Product(s): | InRoads, MX, GEOPAK |
Version(s): | 08.11.09+ |
Area: | Cross Sections |
Problem:
When I use the Open Cross Section View tool and open a dynamic cross section view, it is blank. My corridor components are not displayed in the view.
Solution 1:
Use the steps below to resolve this issue:
1. Use the Open Cross Section View tool to open the dynamic cross section view.
2. In the cross section view that you open, right-click and select Delete Dynamic Cross Section Views.
3. Select Yes when asked to Confirm Delete.
4. The cross section view will close. Use the Open Cross Section View tool once more, and the corridor components will be displayed.
Solution 2:
This could also be a result of the reference attachment having an option on for 'Ignore Attachments When Live Nesting'. Please refer to the following article for details:
communities.bentley.com/.../31698.elements-from-a-reference-not-appearing-in-cross-section-views
