| Product(s): | InRoads |
| Version(s): | 08.11.07+ |
| Area: | Tools |
When using the native InRoads Tracking commands, can you have the program show a tracking graphic in the profiles as you are tracking the horizontal alignment? Or have a line track in the Plan view along the alignment as you are utilizing the Vertical Alignment tracking?
There is an option in the variable manager to allow simultaneous tracking for horizontal and vertical alignments. Go to Tools > Variable Manager (if not available, go to Tools > Application Add-Ins and turn on the Variable Manager Add-In) and look for the “Tools – Simultaneous Tracking” option. Toggle it on and select Apply. Now when you track the horizontal or vertical it will track the other dynamically.
