VerticalAlignmentIntervalStationElevationGrade.XSL Report is Blank when Running a Profile Report
Version(s):08.11.09+
Area: Analysis and Reporting
Question:
When running a profile report, the "VerticalAlignmentIntervalStationElevationGrade.XSL" report is blank.
Answer:
In order to generate a profile report at a specified interval, we have to start by running the Horizontal Geometry Report to define the Interval, and be sure to set the “Include Profiles” at the bottom so that the profile information is included as well.
(Also demonstrated in a video here: Video: Generating Profile Report at a Specified Interval )
