Product(s): | InRoads, GEOPAK, MX |
Version(s): | 08.11.09+ |
Area: | |
Original Author: | Holly Herring, Bentley Technical Support Group |
What variable within the msconfig.cfg file defines the location of the prefs folder that contains the civil preferences and commands?
_USTN_HOMEROOT
The OpenRoads commands inside GEOPAK, InRoads, and MX will look at the _USTN_HOMEROOT variable, then create a folder named "prefs" at that location, then "civil" and "civil_commands" folders in which it stores the various command preferences.
