Product(s): | InRoads, MX, GEOPAK |
Version(s): | 08.11.09+ |
Area: | Basic Settings |
Original Author: | Jacquelyn Pettus, Bentley Technical Support Group |
Question:
Where do I define my feature definition libraries in my workspace?
Answer:
Feature definition libraries are defined in the variable, CIVIL_CONTENTMANAGEMENTDGNLIBLIST. To add a feature definition DGNLIB to this variable:
- Go to Workspace>Configuration in the MicroStation menu.
- Locate the variable, CIVIL_CONTENTMANAGEMENTDGNLIBLIST, in the list.
- Select Edit.
- Change the Edit Mode to "Append" and add the file path to the DGNLIB you wish to add.
You can also use a wild card to capture all DGNLIBs in the specified folder.
- Select OK.
- Save the configuration file.
- Exit and relaunch the product for the change to take effect.
