Suggested Document Viewers [TN]
 Product(s):ProjectWise Explorer
 Version(s):All
 Environment: N/A
 Area: N/A
 Subarea: N/A
Suggested Document Viewers for use with ProjectWise Explorer
ProjectWise Explorer does not deliver any third-party viewing applications, as there are many to choose from and you may use whichever ones you prefer. Many vendors provide free viewers for the files created by their editing applications, much in the same way that Bentley Systems provides Bentley View for viewing DGN files created by MicroStation. Below is a list of links to some common viewing applications (for non-DGN or DWG file types) that you can download and use for free. Note that Bentley Systems does not endorse the use of one viewing application over another, and this is not a list of officially supported or recommended viewing applications. You are under no obligation to use any of the viewers listed, this list is simply provided for your convenience.
External Links
Bentley LEARN Server
Comments or Corrections?
