SELECTserver Gateway error 1053
SELECTserver Licensing Landing Page
When installing SELECTserver Gateway version 9.0, and .NET 4.0 is not installed, the SELECTserver Gateway
service will not start and will display Error 1053 when you manually attempt to start the service. See Details Below:
Error 1053 is a Microsoft error message. In relation to SELECTserver Gateway, this issue is caused by either .NET 4.0 not being installed on the machine or the .NET 4.0 installation is corrupted.
To resolve the issue, please run the dotNetFx40_Full_x86_x64.exe file (Be sure to run as an administrator). This is located in the SELECTServer_09.00.00.XXX extraction folder. If it is already installed, locate and repair the .Net 4.0 installation. Once verified, retest the SELECTserver gateway service again.
NOTE: The current SELECTserver Gateway installer does "NOT" put these prerequisites in place.
Software Prerequisites - SELECTserver Gateway requires:
Additional information on the Gateway error 1053 can also be found in the SELECTserver 9 Known Issues article:
http://communities.bentley.com/products/licensing/w/licensing__wiki/selectserver-9-known-issues.aspx
