| Version(s): | 10.02.00.60+ |
| Area: | ProjectWise Design Integration |
| Original Author: | Holly Herring, Bentley Technical Support Group |
When I open a dgn from ProjectWise that has a managed workspace assigned to it, it does not load the managed workspace. It loads a local workspace. How do I strip the local WorkSpace and WorkSet from this dgn so that it will load the ProjectWise workspace?
Stripping the WorkSpace and WorkSet from a dgn is necessary if you dragged and dropped a local dgn to ProjectWise, and want to open the dgn within the ProjectWise managed workspace. If you don't run this command, it will open the local WorkSpace/WorkSet that is associated to the dgn.
Go to OpenRoads Modeling > Home > Primary > Key-In
Key-in File disassociateworkset then hit Enter. This will remove the WorkSet from the dgn.
*NOTE: If you do a File > Save Settings after running this key-in it will re-associate the WorkSpace and WorkSet to the dgn. Be sure NOT to do a File > Save Settings after running the key-in.
