| Version(s): | 10.00.00.120+ |
| Area: | Drawing Production |
| Original Author: | Holly Herring, Bentley Technical Support Group |
Can I set a default Feature Definition so that I don't have to select the same Feature Definition every time I use a different tool?
You can do this by setting an Active Feature Definition. Go to OpenRoads Modeling > Geometry > General Tools. Under Standards select the Feature Definition Toggle Bar. Use the pull down to set the Feature Definition. Toggle on the Active Feature Definition button.
