| Version(s): | 10.00.03+ |
| Area: | SDK |
For SDK support, please post questions/discussions here: https://communities.bentley.com/products/programming/civil_programming/f/civil_programming_forum
Is there an SDK available for OpenRoads Designer?
The OpenRoads Designer SDK is available as a separate download from the Software Fulfillment Center.
After installing, documentation and a Developer Guide are available at this location: C:\Program Files\Bentley\OpenRoadsDesignerCONNECTSDK
