| Version(s): | 10.00.00.120+ |
| Area: | Geometry |
| Original Author: | Holly Herring, Bentley Technical Support Group |
Question:
How do I remove intervals from civil geometry elements?
Answer:
Locate the civil geometry element in Home > Primary > Explorer > OpenRoads Model. There you will see the intervals, with the original element name as a child of the interval.
Highlight the name of the interval geometry element, right-click to display the pop-up menu, and select Remove Intervals.
