What's New in ProjectWise Cloud
NOTICE OF CHANGE:
Future updates and announcements for ProjectWise Cloud releases will no longer be posted on this page. Please visit the ProjectWise Announcements Forum to stay up to date with all upcoming releases and changes.
26.00.2 - August 02, 2026
The ProjectWise team is excited to announce that ProjectWise Cloud 2026.0.2 has been released and is currently rolling out to all ProjectWise Cloud systems.
Upcoming ProjectWise SQL Attribute Deprecation Notice
ProjectWise Cloud will gradually discontinue support for SQL attributes. Begin preparing for this change to ensure a smooth transition. Our support team is available to assist with any questions you may have. For complete details, review "ProjectWise Attribute SQL Deprecation and CEL Adoption" in ProjectWise Cloud Help.
For more details, see New in ProjectWise Cloud 2026.0.2.
26.00.1 - June 26, 2026
The ProjectWise team is excited to announce that ProjectWise Cloud 2026.0.1 has been released and is currently rolling out to all ProjectWise Cloud systems.
  • iCS for PDF now supports:
    • MicroStation 2026 (26.0.0.178)
    • OpenRoads Designer 2025 (25.0.1.10)
    • OpenRail Designer 2025 (25.0.1.10)
    • OpenBridge Modeler 2025 (25.0.1.25)
Security, performance, and stability improvements.
For more details, see New in ProjectWise Cloud 2026.0.1.
26.00.0 - May 22, 2026
The ProjectWise team is excited to announce that ProjectWise Cloud 2026.0.0 has been released and is currently rolling out to all ProjectWise Cloud systems.
  • ProjectWise Attribute SQL Deprecation
    Upcoming Deprecation Notice: ProjectWise Cloud will gradually discontinue SQL attribute support. Please begin preparing for this change to ensure a smooth transition. Our team is available to assist with any questions you may have.
    ProjectWise Cloud will phase out SQL attribute support requiring CEL for new attribute configurations. The transition will occur in stages, with a soft transition in August 2026, and final deprecation by November 2026.
    For complete details, see "ProjectWise Attribute SQL Deprecation and CEL Adoption", in ProjectWise Cloud Help.
  • Enhanced Security Mode Setting in ProjectWise Administrator - A new Enable Enhanced Security mode setting is now available from the Settings tab in the Datasource Properties dialog. This setting allows ProjectWise Administrators to view and control Enhanced Security mode for their datasources.
    For complete details, see "Enhanced Security Mode" in ProjectWise Cloud Help, and "Datasource Properties Dialog - Settings Tab (Datasource Settings) " in ProjectWise Administrator Help.
For more details, see New in ProjectWise Cloud 2026.0.0.
25.00.5 - April 27, 2026
The ProjectWise team is excited to announce that ProjectWise Cloud 2025.0.5 has been released and is currently rolling out to all ProjectWise Cloud systems.
ProjectWise CEL Enhancements - Library Expressions
CEL expressions that are stored in the database and can be called from other CEL Expressions are new in this release.
For more details, see New in ProjectWise Cloud 2025.0.5.
25.00.4 - March 19, 2026
The ProjectWise team is excited to announce that ProjectWise Cloud 2025.0.4  has been released and is currently rolling out to all ProjectWise Cloud systems.
ProjectWise CEL
ProjectWise CEL is now a fully released feature, and is ready for use in production environments. Bentley recommends using ProjectWise CEL in all new configurations in ProjectWise Cloud.
For more details, see New in ProjectWise Cloud 2025.0.4.
25.00.3 - February 25, 2026
The ProjectWise team is excited to announce that ProjectWise Cloud 2025.0.3 has been released and is currently rolling out to all ProjectWise Cloud systems.
Datasource Licensing
  • Licensing settings for datasources are now managed by ProjectWise Cloud
ic_technical_preview_16px.png ProjectWise CEL Enhancements
  • Four new filter lookup functions are now available: filterNotEquals, filterNotContains, filterIn, and filterNotIn
  • Users from multiple user lists or groups can now be retrieved using built-in lookups
  • Environment import and export using ProjectWise Administrator now includes CEL expressions in attributes and environment lookup definitions
  • Data import and export using standalone ProjectWise Import and ProjectWise Export tools now includes CEL expressions in environment attributes, Work Area properties, and lookup definitions
  • Breaking Change: Starting with this release, all values in WorkArea.properties are now stored as strings instead of matching data type of each Work Area property
For more details, see New in ProjectWise Cloud 2025.0.3
25.00.2 - January 23, 2026
Workflow Rules Engine Enhancements
For more details, see New in ProjectWise Cloud 2025.0.2
25.00.0 - November 7, 2025
NOTE: The next release of ProjectWise Cloud will have user-defined version expressions in the Workflow Rules Engine enabled by default; ProjectWise Administrators who need to configure WRE rules will require ProjectWise Administrator v. 2024.0.3 or higher.
For more details, see New in ProjectWise Cloud 2025.0.0.
24.00.5 - August 25, 2025
[ic_technical_preview_16px.png Technical Preview] ProjectWise CEL Enhancements
For more details, see New in ProjectWise Cloud 2024.0.5.
24.00.3 - June 6, 2025
NOTE: ic_technical_preview_16px.png Technical preview features are not enabled by default. Please create a Bentley Service Case, if you are interested in trying it out.
For more details, see New in ProjectWise Cloud 2024.0.3.
24.00.2 - March 3, 2025
For more details, see What's New in ProjectWise Cloud 2024.00.2 (ProjectWise Cloud Only).
24.00.1 - November 25, 2024
Also, ProjectWise Administrator 2024.00.1 and ProjectWise Explorer 2024.00.1 were released (see New in ProjectWise Explorer 2024.00.1 )
24.00.00 - October 4, 2024
For more details, see What's New in ProjectWise 2024 (ProjectWise Cloud Only)
Note: This release will be rolled out to all ProjectWise Cloud environments over the coming weeks.
23.06.04 – July 8, 2024
23.06.03 - May 22, 2024
For more information, see ProjectWise Design Integration What's New 2023.06.03.
23.06.02 - March 27, 2024
23.06 - February 13, 2024
ProjectWise Design Integration 2023 has now been released. For more details, see ProjectWise 2023 Design Integration Server is Now Released! - ProjectWise Announcements Forum - ProjectWise - Bentley Communities.
Note: All ProjectWise Design Integration 2023  installations will be pushed out to the ProjectWise Cloud environment over the coming weeks.
23.05 - December 4, 2023
23.04 - October 27, 2023
23.03 - September 18, 2023
23.02 - August 10, 2023
23.01 - June 2, 2023
First release of ProjectWise 23 to cloud first platform.
