Product(s): | OpenRoads Designer |
Version(s): | 10.04.00.48 |
Area: | Installation |
Question:
Is OpenRoads Designer able to integrate with AutoCAD? Previously users were given an option to open design files and then launch InRoads. Does this functionality exist within OpenRoads Designer?
Answer:
Due to the successful integration of Autodesk’s RealDWG in Bentley’s OpenRoads Designer product, it is no longer necessary to integrate directly with AutoCAD for DWG deliverables. Users can work directly in a DWG in OpenRoads Designer. OpenRoads Designer CONNECT Edition is a standalone product, built on the MicroStation platform. For these reasons, it is not necessary to OpenRoads Designer with AutoCAD.
