Question:
How to truncate the path length in order to see the file name and type (2D & 3D dgn) at the top of the window regardless of the Path Length ?
Answer:
Change the configuration variable of MS_FULLPATHINTITLEBAR = 0 then exit from OpenRoads Designer and launch OpenRoads Designer.
