| Version(s): | 10.04+ |
| Area: | Survey |
This video demonstrates the use of the delivered "SmartObjects.mvba" to rotate the cell of a point relative to another linear feature. This example MVBA file is delivered to the C:\Program Files\Bentley\OpenRail Designer CONNECT Edition\OpenRailDesigner\Default\SurveyFiles\Macros\mvba folder by default, and contains many examples of the types of macros that can be run on the survey data after import.
Click the video below to play it. To view in fullscreen mode, first click the YouTube link at the bottom of the video to launch the video on the YouTube site. Then, click the fullscreen button (rightmost button at bottom of video).
