Product(s): | OpenRoads Designer |
Version(s): | 10.+ |
Area: | Geometry |
Original Author: | Holly Herring, Bentley Technical Support Group |
Question:
How do I create an Event Point List that places points along an Edge of Pavement at the even stations of the centerline?
Answer:
- Click OpenRoads Modeling > Geometry > Common Tools > Event Point List
- Locate Edge of Pavement you want to add Event Points to. This will open the Event Point dialog box if points have already been added; otherwise, you will be prompted to add Event Points.
- Set your Placement Method to Station Offset
- Click within the dialog box to add by station offset
- Snap to the Centerline Station you want. Set offset to zero. Data point to accept. You can see in the below screenshot snapping to the 4+00 centerline creates an event point along the edge of pavement at station at 3+92.
- Continue until all event points are created.
