Product(s): | OpenRoads Designer |
Version(s): | 10.08.01.33+ |
Area: | Geometry |
Original Author: | Holly Herring, Bentley Technical Support Group |
Question:
How do I edit and customize the heads up prompt for Civil AccuDraw?
Answer:
1. Go to OpenRoads Modeling > Geometry > General Tools > Civil Toggles and click Civil Accudraw. Then toggle Civil AccuDraw to On.
2. Click on the Shortcuts icon, then in the Civil AccuDraw Settings dialog box go to the Favorites tab.
3. From here you can edit, add, delete and customize your Civil AccuDraw Settings
