| Version(s): | 08.11.09+ |
| Area: | 3D Geometry |
Question:
How do you generate a sloped surface using OpenRoads tools? This was previously accomplished using the Generate Sloped Surface command in the native InRoads product. Is there an equivalent OpenRoads tool?
Answer:
The tool used to generate a sloped surface in OpenRoads is the Create 3D By Slope To Target tool located in the 3D Geometry section of the Civil Tools Tasks. This tool creates a 3D element computed from a linear element to a surface.
The video at the link below provides a demonstration of this tool.
communities.bentley.com/.../26533.video-designing-a-building-pad
