| Product(s): | OpenRoads Designer Connect Edition |
| Version(s): | 10.02.00.60+ |
| Area: | Subsurface Utilities |
This video shows how conduit sizes are defined - either using a table within the feature definition, or (for storm and sanitary conduits) by using a hydraulic prototype. It also shows how the SUDA_USE_HAESTAD_CONDUIT configuration variable affects this.
