Enable Perpendicular Template Drops setting in Corridor Feature Definition
Product(s):OpenRoads Designer
Version(s):10.09+
Area: Corridors, Linear Templates
Question:
What does "Enable Perpendicular Template Drops" do in the Corridor and Linear Template Feature Definitions?
Answer:
When set to "False", templates are dropped vertically.  This is typical for most civil engineering design.
When set to "True", templates are dropped normal to the vertical profile.  This is desirable for some tunnel design scenarios.
