Applies To | |||
Product(s): | Power InRoads | ||
Version(s): | 08.11.09.493 | ||
Environment: | N/A | ||
Area: | Surface | ||
Subarea: | |||
Original Author: | Chris Key, Bentley Technical Support Group | ||
I have an old Caice surface file *.lzh extension. Can I import it into InRoads? If so, how?
Bentley does not have a translator that will translate the LHZ format to a survey fieldbook. One option is to try the GDOT CAICEALL.exe to see if you can convert the LHZ file to a format that can be imported into InRoads.
