| Version(s): | 10.10.01.03+ |
| Area: | Drawing Production |
Question:
Is it possible to setup a labeling format to label a point on an alignment in Straight Line Format (SLM) rather that the normal station format (Sta. 100+00 to SLM 1.8939 miles)?
Answer:
- Open the Text Favorite Manager.
- Create a new Text Favorite
- Set the following:
- Field Type: Civil Element Properties
- Field Sub Type: Plan Annotation then navigate to Point > Point Distance
- Linear Units Format > Master Units to desired units. It is set to Miles in the screenshot.
- Hit Accept then Save. Close Text Favorite Manager
- Open the Annotation Group and set the needed Annotation Definition to point to the newly created Text Favorite.
- Annotate Text.
