Daily Peak Application Usage
Subscription Analytics Landing Page
We are rolling out a new reporting framework starting July 1st to make your experience faster. While some parts of the reports will look a bit different, they will mainly work the same. You can learn more about the changes here.
Purpose
View the Peak usage of Bentley applications by day and country. Since Peaks are determined by Application and Country, many of the visuals require both a Product and a Country to be selected. It is also recommended, but not required, to select Feature String.
Roles
Users with at least one of the following roles are able to access the report:
Access
  1. Go to the Subscription Analytics
  2. Click on the Daily Peak Application Usage
Filters
For an accurate analysis of your peak application usage, the Country, Product, and Feature String (where applicable) filters should all be used.
Name
Description
Usage Date
Custom date range. The default selection of Date is the past 365 days.
Country
User's Entitlement Country
Product
Product with ProductID
Feature String
Feature String
Layout - Summary
This is some overall information about your Peaks.
Name
Description
Days Used
Number of days the product was used at least once
Days Term Licenses Used
Number of days there was at least one term license used
Peak Usage
The highest peak in the time frame
Checkouts
Number of usages that were checkouts
Covered Perpetual Licenses
Number of licenses that are part of the contract today.
Max Term Licenses
Largest number of term licenses that would be consumed according to the number of covered licenses today
Layout - Peak Usage by Country
It shows the Sum of Checkouts and Standard Usage by Entitlement Country.
Layout - Peak Usage by Day
Name
Description
Day
Usage Date
Checkouts
Number of usages that were Checkouts
Perpetual License Usage
Number of usages that were neither term licenses or Checkouts
Term License Usage
Number of term licenses that would be consumed according to the number of covered licenses today
Covered Licenses
Indicates the number of covered licenses today
Layout - Usage by Product and Country
Name
Description
ProductID
Product ID
Product
Product and Feature String
Country
Entitlement Country
Usage Date
Usage Date
Peak Pooled Usage
Sum of Checkouts, Term Licenses, and Perpetual Licenses
Checkouts
Number of checkouts
Peak Usage
Sum of Term and Perpetual Licenses
Number of covered licenses today
Term License Usage
Other Language Sources
Deutsch
