| Product(s): | OpenRoads Designer Connect Edition |
| Version(s): | 10.00.00+ |
| Area: | Geometry: Vertical |
In this video we will demonstrate how to use the Quick Profile From Surface to display a surface profile in the Profile Model of an element. Then we can set that Surface Profile as the Active Profile to rule the vertical gradeline to the referenced Terrain Model.
Click the video below to play it. To view in fullscreen mode, first click the YouTube link at the bottom of the video to launch the video on the YouTube site. Then, click the fullscreen button (rightmost button at bottom of video).
For pre-CONNECT Edition versions of OpenRoads Designer, the same command and functionality exists. You can refer to the following wiki article for V8i specific content:
https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0020840
