Video: Adding Custom Configuration location through Manage Configuration dialog
                   Product(s): OpenRoads Designer, OpenRail Designer, OpenSite Designer
Version(s): 10.11+
Area: Standards
Original Author: Bentley Civil Technical Support
This video will demonstrate how to use the Manage Configuration options to point to custom configuration locations to load workspaces from different local or shared network locations.
