Products Using Subscription Entitlement Service
Subscription Services Landing Page
What is the purpose of this information?
Starting in October 2018, all newly released Bentley CONNECT Edition product versions will utilize the Subscription Entitlement Service (formerly known as "CONNECT Licensing") instead of SELECTserver. These are activated using a Bentley login, not a site activation key. Following is a product list with the first versions to use the Subscription Entitlement Service.
NOTE:
As per our support policy for desktop applications, support for Bentley V8i SELECTseries 10 applications has been discontinued as of January 01, 2022. For more information, see: Support for V8i SELECTseries 10 applications after December 31st, 2021
Name Version
AECOsim Building Designer 10.04.00.69
Assetwise Reliability (APM) 07.15.36.14
AutoPIPE 12.00.00.14
AutoPIPE Advanced 12.00.00.14
AutoPIPE Nozzle 12.01.00.10
AutoPIPE Nuclear 12.00.00.14
AutoPIPE Vessel 41.00.00.06
AutoPIPE Vessel Code British 41.00.00.06
AutoPIPE Vessel Code Euro 41.00.00.06
AutoPIPE Vessel Code French 41.00.00.06
AutoPIPE Vessel Code German 41.00.00.06
AutoPIPE Vessel Code Russian 41.00.00.06
AutoPIPE Vessel Code USA 41.00.00.06
AutoPIPE Vessel Enterprise 41.00.00.06
AutoPLANT Modeler CONNECT Edition 10.00.00.36
Bentley CulvertMaster CONNECT Edition 10.03.00.03
Bentley Descartes 10.04.00.25
Bentley Descartes for MicroStation 08.11.09.905
Bentley Facilities Space Planner 10.02.00.23
Bentley FlowMaster CONNECT Edition 10.02.00.01
Bentley GEOPAK Civil Engineering Suite (SELECTseries 10) 08.11.09.918
Bentley GEOPAK Road (SELECTseries 10) 08.11.09.918
Bentley LumenRT 16.11.05.50
Bentley Map (OpenCities Map) 10.02.00.18
Bentley Map Enterprise (OpenCities Map Enterprise) 10.02.00.18
Bentley Map PowerView (OpenCities Map PowerView) 10.02.00.18
Bentley MXROAD 08.11.09.907
Bentley OpenPlant 2D iModel Bridge 10.01.00.36
Bentley OpenUtilities Analysis 10.02.00.05
Bentley OpenUtilities Designer 10.03.00.04
Bentley OpenUtilities sisNET CONNECT Edition 10.04.00.08
Bentley OpenUtilities sisHYD Gas (SELECTseries 10) 08.11.09.74
Bentley OpenUtilities sisHYD Heat (SELECTseries 10) 08.11.09.74
Bentley OpenUtilities sisHYD MultiUtility (SELECTseries 10) 08.11.09.74
Bentley Pointools 10.01.00.01
Bentley Rail Track 08.11.09.918
Bentley Rail Track Suite 08.11.09.918
Bentley Raceway and Cable Management 10.00.00.127
Bentley Speedikon 10.00.00.25
Bentley View 10.11.00.41
CNCCBIM OpenRoads 10.06.01.09
ContextCapture 04.04.11.60
ContextCapture Center (Engine) 04.04.11.60
ContextCapture Center (Master) 04.04.11.60
ContextCapture Editor 10.03.00.23
ContextCapture Viewer 04.04.11.60
CUBE CONNECT Edition 06.05.00.00
EasyPower 2024 24.00.00.807
EMME CONNECT Edition 04.07.00.11
GeoStudio 11.04.00.18
gINT Civil Tools Professional Plus 10.03.00.13
gINT Logs 10.00.01.07
gINT Professional 10.00.01.07
gINT Professional Plus 10.00.01.07
HoleBASE Civil 3D 2018 CONNECT Edition 02.22.02.72
HoleBASE Civil 3D 2019 CONNECT Edition 02.22.02.72
HoleBASE CONNECT Edition (Data Entry, Standard, Professional) 01.34.02.86
HoleBASE Microsoft Excel CONNECT Edition 01.22.02.21
HoleBASE Template Studio CONNECT Edition 01.20.02.23
iModel Bridge for PDMx 10.03.00.06
InRoads V8i 08.11.09.918
InRoads Suite V8i 08.11.09.918
ISM Revit Plug-in 11.00.00.05
Japan KHK2 Code for AutoPIPE 12.00.00.14
KeyLAB CONNECT Edition 02.07.00.94
LARS Bridge 20.00.00.32
LEAP Bridge Concrete 18.02.00.12
LEAP Bridge Steel 18.02.00.12
LEGION Model Builder 01.06.05.03
LEGION Simulator 01.06.05.03
MAXSURF 22.00.00.97
MAXSURF Advanced 22.00.00.97
MAXSURF Enterprise 22.00.00.97
MAXSURF Modeler Advanced 22.00.00.97
MAXSURF Stability Advanced 22.00.00.97
MAXSURF Stability Enterprise 22.00.00.97
Microstran 10.00.00.14
Microstran.Advanced 10.00.00.14
Microstran.Pro 10.00.00.14
MicroStation CONNECT Edition (Update 11) 10.11.00.36
MicroStation V8i (SELECTseries 10) 08.11.09.908
MicroStation PowerDraft CONNECT Edition (Update 11) 10.11.00.36
MicroStation PowerDraft V8i (SELECTseries 10) 08.11.09.912
MOSES 11.00.00.97
MOSES Advanced 11.00.00.97
MOSES Enterprise 11.00.00.97
Multiframe 22.00.00.97
Multiframe Advanced 22.00.00.97
OpenBridge Designer 10.06.00.22
OpenBridge Designer CCK 10.06.00.34
OpenBridge Modeler 10.06.00.41
OpenBuildings Designer (formerly AECOsim Building Designer) 10.04.00.69
OpenBuildings Station Designer 10.05.00.19
Opencities Map CONNECT Edition (Update 2) 10.02.00.18
Opencities Map V8i (SELECTseries 10) 08.11.09.908
Opencities Map Enterprise CONNECT Edition (Update 2) 10.02.00.18
Opencities Map Enterprise V8i (SELECTseries 10) 08.11.09.908
OpenCities Map PowerView CONNECT Edition (Update 2) 10.02.00.18
OpenCities Map PowerView V8i (SELECTseries 10) 08.11.09.922
OpenFlows CivilStorm 10.02.00.55
OpenFlows FLOOD 10.00.02.01
OpenFlows FlowMaster 10.02.00.01
OpenFlows HAMMER 10.02.00.43
OpenFlows PondPack 10.02.00.01
OpenFlows SewerCAD 10.02.00.55
OpenFlows SewerGEMS 10.02.00.55
OpenFlows StormCAD 10.02.00.55
OpenFlows WaterCAD 10.02.00.43
OpenFlows WaterGEMS 10.02.00.43
OpenPlant Isometrics Manager 10.02.00.36
OpenPlant Modeler 10.02.00.37
OpenPlant Orthographics Manager 10.02.00.36
OpenPlant PID 10.02.00.36
OpenPlant Project Administrator 10.02.00.36
OpenPlant Support Engineering 10.02.00.36
OpenRail ConceptStation 10.00.09.20
OpenRail Designer 10.06.00.38
OpenRoads ConceptStation 10.00.09.20
OpenRoads Designer 10.06.00.38
OpenRoads SignCAD 10.00.00.12
OpenRoads SignCAD Viewer 10.00.00.12
OpenSite Designer 10.07.00.56
OpenTower Comms Visa (formerly STAAD Tower Comms Visa) 10.00.02.00
OpenUtilities Design Optioneering 10.03.00.07
OpenUtilities Substation (formerly Bentley Substation) 10.02.00.25
Orbit 3DM Content Manager :20.09.00.01
Orbit 3DM Feature Extraction Basic / Standard / Pro 21.01.00.01
Orbit 3DM Import & Upload Tool 22.04.00.01
Orbit 3DM Publisher 22.04.00.01
Plant Exporter 10.03.00.06
PLAXIS 2D CONNECT Edition 20.00.00.119
PLAXIS 3D CONNECT Edition 20.00.00.119
PowerCivil for Countries V8i 08.11.09.917
Power GEOPAK V8i 08.11.09.918
Power InRoads V8i 08.11.09.918
Power Rail Track 08.11.09.918
PowerSurvey 08.11.09.918
ProjectWise Design Integration CONNECT Edition - Admin Setups
10.00.03.434
ProjectWise Design Integration CONNECT Edition - Client Setups
10.00.03.434
ProjectWise InterPlot Driver Pack CONNECT Edition 10.00.02.29
ProjectWise Interplot Organizer CONNECT Edition 10.00.02.29
ProjectWise InterPlot Raster Offline Driver Pack CONNECT Edition 10.00.02.29
ProjectWise Interplot Server CONNECT Edition 10.00.02.29
Promis.e 10.00.00.49
ProStructures (Update 2) 10.02.00.20
RAM Concept 07.00.00.12
RAM Concept Post Tension 07.00.00.12
RAM Concrete 16.00.00.28
RAM Connection 13.00.00.56
RAM Elements 16.00.00.37
RAM Foundation 16.00.00.28
RAM Frame Analysis 16.00.00.28
RAM Frame Steel Design 16.00.00.28
RAM Modeler 16.00.00.28
RAM SBeam 07.00.00.111
RAM Steel 16.00.00.28
RAM Structural System 17.00.00.93
RM Bridge 11.04.00.17
RM Bridge Advanced 11.04.00.17
RM Bridge Enterprise 11.04.00.17
SACS Collapse 13.00.00.01
SACS Fatigue 13.00.00.01
SACS Fatigue Advanced - Dynamic Response 13.00.00.01
SACS Fatigue Advanced - Wave Response 13.00.00.01
SACS Fatigue Enterprise 13.00.00.01
SACS Marine 13.00.00.01
SACS Marine Advanced 13.00.00.01
SACS Offshore Structure 13.00.00.01
SACS Offshore Structure Advanced 13.00.00.01
SACS Offshore Structure Enterprise 13.00.00.01
SACS Pile Structure Design 13.00.00.01
SACS Wind Turbine 13.00.00.01
SOILVISION CONNECT Edition 10.00.00.13
SpidaCalc 08.00.00.280
STAAD Advanced Concrete Design RCDC 08.00.00.16
STAAD.Pro CONNECT Edition 22.00.00.15
STAAD.Pro Advanced CONNECT Edition 22.00.00.15
STAAD Foundation Advanced 09.00.00.09
STAAD RCDC FE 03.00.00.11
Structural Enterprise *
Substation China 10.03.00.16
SYNCHRO OpenViewer 06.01.01.01
SYNCHRO Pro 06.01.01.01
SYNCHRO Pro - Iray Add-on 06.01.01.01
SYNCHRO Scheduler 06.01.01.01
* The Structural Enterprise License bundle works with CONNECT Licensing so long as all the individual product versions being used are on CONNECT Licensing.
Other Language Sources
Deutsch
Español
Français
Italiano
Polski
