| Product(s): | OpenRoads ConceptStation |
| Version(s): | 10.00.11+ |
| Area: | GeoCoordination Services |
| Original Author: | Purva Lakde. Product Advantage Group |
Question:
OpenRoads ConceptStation will not connect to the GeoCoordination services. An error occurred GeoCoordination Service Error: GeoCoordination Services unreachable
Answer:
1. Go to the backstage settings, leave the Proxy Address text box empty.
2. Hit the Test button
If you get the Proxy Test Successful, please refer to this Wiki article OpenRoads ConceptStation - Access to web sites - OpenRoads | OpenSite Wiki - OpenRoads | OpenSite - Bentley Communities
If you get the following error: "self signed certificate in certificate chain"
You will need to follow the steps below to edit the PEM file delivered with ConceptStation.
Editing the PEM FILE:
Double check that the certificate chain has not been altered using the following steps
3. Click on Certificate
4. Go to the Certification Path
Note : If you don't see the same certificate chain as above, it means that your provider is decrypting https communications and re-encrypting them using a different certificate
To solve the problem, you’ll need to do the following steps for both the first and second certificates.
4. This will open the Certificate Export Wizard where you want to pick the Base-64 encored X.509 (.CER) option
Repeat the process for the other certificates and try the workflow again in ConceptStation. You do not need to export the bentley.com certificate.
