Creating an E5-1a Exit Gore sign as a multi-panel
Question:
How do I create an E5-1a Exit Gore sign as a multi-panel within OpenRoads SignCAD?
Answer:
Using separate panels makes it easier to align the objects (text and arrow) within the sign as needed and also edit the exit number and keep the equal left and right spacing on it.
Here is a video that shows the process for creating the E5-1a Exit Gore sign as a multi-panel sign.
