Product: |
OpenRoad SignCAD 2023 & 2024 |
Version: |
23.00.00.151 & 24.00.00.56 |
Area: |
How-to |
Original Author: |
Bentley Global Technical Support |
Step 1: In OpenRoads SignCAD, pick Panels>Rectangular. The Rectangular tool is used to create a rectangular sign panel that automatically adjusts in size as objects are added to or removed from it.
Step 2: The Place Rectangular Panel dialog shows the default panel parameters and includes the following groups: General, Size, Border, Spacing, Attributes and Appearance. You can set the panel properties before placing the panel.
NOTE: The Rectangular Panel Properties can be edited after creation through the Properties dialog.
Step 3: A small cross-hair cursor identifies where the panel will be located. Left-click to place the Rectangular Panel on the workspace and close the dialog.
