Product: |
OpenRoad SignCAD 2023 & 2024 |
Version: |
23.00.00.151 & 24.00.00.56 |
Area: |
How-to |
Original Author: |
Bentley Global Technical Support |
Introduction: The instructions and video below show how-to place a Standard Sign Panel in OpenRoads SignCAD.
Step 1: In OpenRoads SignCAD, pick Panels>Standard Sign. The Standard Sign tool is used to create fixed-size rectangular and non-rectangular panels (Octagon, Equilateral Triangle, Round, Pennant, Diamond and Pentagon).
Step 2: The Place Standard Sign Panel dialog shows the default panel parameters and includes the following groups: General, Size, Border, Spacing, Attributes and Appearance. You can set the panel properties before placing the panel.
NOTE: The Standard Sign Panel Properties can be edited after creation through the Properties dialog.
Step 3: A small cross-hair cursor identifies where the panel will be located. Left-click to place the Standard Sign Panel on the workspace and close the dialog.
