Product: |
OpenRoad SignCAD 2023 & 2024 |
Version: |
23.00.00.151 & 24.00.00.56 |
Area: |
How-to |
Original Author: |
Bentley Global Technical Support |
Introduction: The instructions and video below show how to delete a sign panel in OpenRoads SignCAD.
Step 1: Select the Panel. Click on Panels>Panel Selection. Pick the Element Selection tool and left-click on the panel to select it. See Selecting & Moving a Sign Panel - OpenRoads | OpenSite Wiki - OpenRoads | OpenSite - Bentley Communities.
Step 2: Delete the Panel. With the panel selected, pick General>Delete to remove the panel from the workspace. Notice that the Status Bar on the bottom shows 1 Element Deleted.
