Product: |
OpenRoad SignCAD 2023 |
Version: |
23.00.00.151 |
Area: |
How-to |
Original Author: |
Bentley Global Technical Support |
The instructions and video below show how-to place text in OpenRoads SignCAD 2023.
The Place Text tool is used to create new text. The Kerning Method can be used to adjust the spacing between letters and Text alignment to set the Top, Middle or Baseline vertical alignment. The Font drop-down shows the Recently used fonts, the Highway fonts and any other TrueType fonts installed in the C:\Windows\Fonts folder on the computer. The text display will update in the dialog as different fonts are selected. The standard text sizes are available from the size drop-down. Additional text sizes can be used by typing in the size field and pressing enter. There are also Bold and Italic options that can be applied. Font Color can be changed in the Color dialog. The Insert Symbol dialog shows the symbols available including the stacked fractions. The default Text dialog background color (tan) can be changed by selecting a different background color from the Color dialog.
