| Version(s): | 10.08+ |
| Area: | General |
This video demonstrates how to create and edit custom coordinate systems in OpenRoads Designer.
The workflow is as follows:
1.) Copy the delivered "Seed.dty" file from the "C:\Program Files\Bentley\OpenRoads Designer CONNECT Edition\OpenRoadsDesigner\GeoCoordinateData"
2.) Paste and rename the DTY in your project location.
3.) Edit the MS_GEOCOORDINATE_USERLIBRARIES variable to point to the new project DTY file.
4.) After re-starting, open the Select Geographic Coordinate System tool and copy existing GCS from the Library to the project DTY.
5.) Right-click on any GCS in the project DTY and select Edit Coordinate System Properties.
Click the video below to play it. To view in fullscreen mode, first click the YouTube link at the bottom of the video to launch the video on the YouTube site. Then, click the fullscreen button (rightmost button at bottom of video).
