Best Practices for Creating a Civil iModel
Product(s): OpenRoads Designer
Version(s): 10.10.21+
Area:  General
Question:
How do I prepare my OpenRoads data to be published to an iModel?
Answer:
  1. Create a 2D container file with OpenRoads Designer.
    • This container file needs to be created from the correct seed file in the Workspace used by the dataset.
    • The container file needs to have the correct GCS for the project.
  2. Attach all needed/required reference files.
    • If the reference file has a default (2D) and default-3D model, attach the default (2D) model only.
    • If the file has only a 2D model(s), attach each desired model as-is.
    • If the file has only a 3D model(s), attach each desired model as-is.
  3. Create a Civil model in the container file that results in the creation of a default-3D
    • e.g. Make terrain active
  4. Review the hierarchy of the reference files. Be sure that ALL required files\models are listed.
    • Ensure the Reference Display = ON for each reference attachment you want to show in the iModel.
    • Set the 3D-Default model within the “container” file to a minimum nesting depth of 1.
Set the configuration variable:
MS_LOCAL_MATERIALS = 1
This will better support materials. If set to 1, materials are copied directly into the dgn as local materials. Use this when you need a dgn to be self-contained and portable. Set it to 0 if you are within a collaborative environment where you can manage the material across multiple projects.
Current Limitations:
Limitations: Terrains
Limitations: Subsurface
Limitations: OpenSite
Video:
www.youtube.com/watch
green
