How can I get a dynamic report of offsets and elevation differences between alignments in OpenRoads/
How can I get a dynamic report of offsets and elevation differences between alignments in OpenRoads/OpenRail?
Something similar to the Dynamic Report Tool in MX.
You can achieve that by the use of Analyze Point.
  1. Select Analyze Point
  2. Select first alignment
  3. Set Near Snap Point
  4. Snap and navigate through the second alignment to get offsets and elevation differences.
