| Product(s): | OpenRoads/Rail/Site Designer |
| Version(s): | 10.+ |
| Area: | Reports |
Question:
I am trying to create a Mass Haul Diagram and the values come out as 0 and the diagram shows a flat grade of 0.. How to resolve this issue?
Answer:
Ensure the mesh cut/fill factors under volume feature definitions are set to a value greater than zero.
