Video: Conduit Slope Construction vs Slope Calculated
Product(s): OpenSite, OpenRoads, OpenRail Designer Connect Edition
Version(s): 10.09.00.+
Area:  Drainage & Utilities
This video demonstrates the difference between the conduit slope construction property and the slope calculated property.
NOTE: New in the 2023 Version of the Open Civil Products You can now choose to use the "construction" length and slope in the hydraulic calculations.
