| Version(s): | 10.07.01.32+ |
| Area: | Survey |
| Original Author: | Chris Key, Bentley Technical Support Group |
This video will demonstrate the technology available to merge and combine separate field books utilizing an OpenRoads Survey Format file (SQLite) as a file format for export and import into a field book. This process will export the current state of the Field Book.
Click the video below to play it. To view in fullscreen mode, first click the YouTube link at the bottom of the video to launch the video on the YouTube site. Then, click the fullscreen button (rightmost button at bottom of video).
