| Product(s): | OpenRoads Designer Connect Edition |
| Version(s): | 2023+ |
| Area: | Drawing Production |
Problem:
The last profile sheet grid does not cover the full sheet and stops where the vertical alignment if finished.
To generate the last profile sheet with the full grid, while creating the named boundaries for profile, Turn on the check box "Last Full Boundary".
Following video demonstrates how to generate the last profile sheet with the full grid.
Click the video below to play it. To view in fullscreen mode, first click the YouTube link at the bottom of the video to launch the video on the YouTube site. Then, click the fullscreen button (rightmost button at bottom of video).
