| Product(s): | OpenSite Designer |
| Version(s): | 10.10.+ |
| Area: | VBA |
Received following message.
VBA rejected the OpenSite Designer Application object. probably because it cannot find the proper version of the type library. Trying running 'OpenSite Designer /regserver' with administrator privileges.
1) Re-register the program.
a) Search "Command Prompt" on start menu and Select "Run as administrator".
b) Type following command in the command prompt window.
"CD C:\Program Files\Bentley\OpenSite Designer 2023.00\OpenSiteDesigner"
(Note: Change the "OpenSite Designer 2023.00" folder name if you are using any other version)
c) Type "OpenSiteDesigner.exe /regserver" and press Enter.
2) Repair the installation.
a) Download the installer from https://softwaredownloads.bentley.com/en/ProductDetails/2758
b) Run the Installer and select Repair.
3) Re-install the application.
a) Refer to following document to detailed steps on how to clean uninstall the OpenRoads/ OpenSite Designer.
https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0018222
b) Re-install the OpenSite Designer.
