| Version(s): | 10.12.+ |
| Area: | Troubleshooting Various Issues |
Problem:
If the Text Favorite contains a combination of MicroStation text and Field Text and the Text Style used for the Text Favorites has Background turned ON, you will see the label with a split line in between the text as shown below.
To resolve it you need to turn off the Visible Edge in the active Display Style.
Please find the video below which demonstrates the above steps.
