| Version(s): | 10.00.00+ |
| Area: | Geometry |
Question:
When I draw profile straights, insert circular curve between them and then remove the curve, information about slope and length of profile lines disappears.
How to bring back information about slope and length after removing profile curve in Profile View?
communities.bentley.com/.../disappearing_2D00_slope_2D00_length_2D00_values-_2800_1_2900_.webm
Answer:
If you want to bring back information about slope and length after removing profile curve in profile view, then you will need to hoover your line and select "Remove Intervals".
Once you click on Remove Intervals, your slope and length information appear back in Profile View.
