Video: Create Fillet in Template Component
Product(s):OpenRoads Designer
Version(s):10.06.00.38+
Area: Corridor Modeling
Original Author:Chris Key, Bentley Technical Support Group
This video demonstrates the new ability to create a fillet transition for a point/corner within a component.  The fillet is defined by a tangent length along the component edge.  The fillet can be applied and adjusted for any point along a component.
https://youtu.be/MAfgTNhJhkE
